Configure IPv6 route preferences to give preference to routes learned for a specific protocol.
Important
Changing route preferences can affect system performance and network accessibility while you perform the procedure. Change a prefix list or a routing protocol before you activate the protocols.
Configure the route preference to RIPng and confirm the configuration is correct.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#ipv6 route preference protocol ripng 10
Switch:1(config)#show ipv6 route preference
                                IPv6 Route Preference - GlobalRouter
PROTOCOL        DEFAULT    CONFIG
LOCAL           0          0
STATIC          5          5
SPBM_L1         7          7
OSPFv3_INTRA    20         20
OSPFv3_INTER    25         25
EBGP            45         45
RIPNG           100        100
OSPFv3_E1       120        120
OSPFv3_E2       125        125
IBGP            175        175
Variable definitions
Use the data in the following table to use the ipv6 route preference and the show ipv6 route preference commands.
| Variable | Value |
| <0-255> | Assigns a route preference value. |
| ebgp | Configures the preference for protocol type EBGP. |
| ibgp | Configures the preference for protocol type IBGP. |
| ospfv3-extern1 | Configures the preference for protocol type OSPFv3 external type 1. |
| ospfv3-extern2 | Configures the preference for protocol type OSPFv3 external type 2. |
| ospfv3-intra | Configures the preference for protocol type OSPFv3 intra-area. |
| ospfv3-inter | Configures the preference for protocol type OSPFv3 inter-area. |
| ripng | Configures the preference for protocol type RIPng. |
| spbm-level1 | Configures the preference for protocol type spbm-level1. |
| static | Configures the preference for protocol type static. |
